SkyDemon BlueTooth RS232
John Brady
John Brady
Too Much Forum (987 reputation)Too Much Forum (987 reputation)Too Much Forum (987 reputation)Too Much Forum (987 reputation)Too Much Forum (987 reputation)Too Much Forum (987 reputation)Too Much Forum (987 reputation)Too Much Forum (987 reputation)Too Much Forum (987 reputation)
Posts: 20, Visits: 23
Skyboy999 - 7/22/2025 3:48:26 PM
John Brady - 6/28/2025 4:54:34 PM
Slightly different question on Bluetooth to RS232.  Have a BT578 dongle to transmit Skydemon track data to Dynon HS34 nav controller driving a D180 autopilot in RV-8.  Can the dongle be left permanantly on and still function (so it can be mounted behind the panel)?
I have not investigated the Dynon set-up requirements yet.
John
Little confused. If you run on its internal power then it won't last long before needing to be recharged. I assume you are powering externally in which case you will doubtless have it wired to some switch (perhaps same as the Dynon?) so the BT578 is only receiving external power when in use. This is fine.
Sorry for the confusion.  This system uses ultra low power so no extra power is required - it operates on the signal as a power source.  But I was not clear on what should be done with the available power switch.  I will set it up and try it out.  Thanks for the reply.
It's important to note that SkyDemon does not control or command your autopilot, it simply tells it about your current route, leg, and GPS position. It's then up to the autopilot to decide what to do with that information. SkyDemon would have nothing to do with your bank angle, roll rate etc.
Unfortunately I do not know the answer to your question, but I thought that clarification might be helpful.
Ronvg
R
Posts: 13, Visits: 21
Hello, can anyone help me with the autopilot settings between SkyDemon via the Irxon BT578V3 adapter and the TruTrak Vizion 385R autopilot of my Dynamic WT9? Everything is installed correctly and the autopilot is receiving commands from SkyDemon through the Irxon, but it does not follow the route precisely — it overshoots and weaves in wide turns over the magenta line, and circles around a waypoint instead of flying over it.
At the moment, I have SkyDemon sending only GPRMC, GPRMB, GPBOD & GPAPB sentences to the autopilot, but I would also like to know the recommended autopilot settings, such as the Lateral Setup values: GPSS GAIN, LAT ACTIVITY, BANK ANGLE, MICROACTIVITY, ROLL REV — and the Vertical Setup values: VRT ACTIVITY, PITCH REV, STATIC LA, & MICROACTIVITY.
Can anyone share these settings or give me tips on how to have my autopilot fly the route from SkyDemon smoothly?
Edited 8/14/2025 7:26:40 PM by Ronvg
Skyboy999
Skyboy999
Posts: 53, Visits: 238
John
John Brady
John Brady
John
Bealeyman
Bealeyman
Too Much Forum (744 reputation)Too Much Forum (744 reputation)Too Much Forum (744 reputation)Too Much Forum (744 reputation)Too Much Forum (744 reputation)Too Much Forum (744 reputation)Too Much Forum (744 reputation)Too Much Forum (744 reputation)Too Much Forum (744 reputation)
Posts: 41, Visits: 103
There is no RS232 port on the GNS430 which i subsequently discovered
nufmuff
nufmuff
Too Much Forum (312 reputation)Too Much Forum (312 reputation)Too Much Forum (312 reputation)Too Much Forum (312 reputation)Too Much Forum (312 reputation)Too Much Forum (312 reputation)Too Much Forum (312 reputation)Too Much Forum (312 reputation)Too Much Forum (312 reputation)
Posts: 9, Visits: 7
Bealeyman - 12/23/2024 10:44:19 AM
Not yet but soon in the New Year. I intend to use a cable out of the back of the GNS430 that ends in a D type connector on the instrument panel. Therefore no permanent connection. Can’t see a problem with that?
Can you use a bluetooth dongle with 430 / 530 and SD for radio frequency selection ?  Does it definitely work?
Bealeyman
Bealeyman
John Wignall
J
Forum Newbie (6 reputation)Forum Newbie (6 reputation)Forum Newbie (6 reputation)Forum Newbie (6 reputation)Forum Newbie (6 reputation)Forum Newbie (6 reputation)Forum Newbie (6 reputation)Forum Newbie (6 reputation)Forum Newbie (6 reputation)
Posts: 1, Visits: 0
Has anyone had experience of installing a bluetooth RS232 dongle to end frequencies from SD to a radio installed in a licensed aircraft?
