Is there a SkyDemon API?
fdemon
fdemon
Too Much Forum (558 reputation)Too Much Forum (558 reputation)Too Much Forum (558 reputation)Too Much Forum (558 reputation)Too Much Forum (558 reputation)Too Much Forum (558 reputation)Too Much Forum (558 reputation)Too Much Forum (558 reputation)Too Much Forum (558 reputation)
Posts: 18, Visits: 140
Is there any way custom functions can be programmed into SkyDemon?
I'm just thinking about a feature to enable guidance to landing areas in the event of engine failure at night.
The rough idea is I generate a set of pseudo airfields by examining maps etc. These would typically be fields that have clear approaches, enough space etc. For each I would choose one or more arbitrary 'runways'.
In the event of an engine failure some UI control would call up a process to load all the pseudo airfields within say 5 miles of the aircraft current GPS position. They would then appear on SkyDemon along with the normal indicators of 'runways'. Ideally the synthetic ILS glidepath would be changed to say 8 degrees.
The pilot could then use the in-built glide zone feature to pick a pseudo airfield to aim for.
Any programming features available?
No, sorry.
