AIRAC 2403 rev 1 wrong VRP
Freccia
F
Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)Too Much Forum (607 reputation)
Posts: 30, Visits: 171
Hi, with the new AIRAC in force from today, among other things, the Verona CTR has been modified. On SD the change is already visible however the old VRP "Desenzano" (POE1) is still present which no longer exists, because it was replaced by "Moniga del Garda" (same acronym POE1). I add that the VRP Brescia will be moved further west, changing its name to "Brescia Costalunga" (PON1). A new zone of the Milan CTA called 29 "GUSSAGO" will also be established from 2500 feet to FL195.
Edited 3/21/2024 9:11:11 AM by Freccia
Hi Freccia, there was not a change to ENR 6.3.1 the list of VRPs in today's AIRAC update. The last update to this document was effective 2023-11-30. Perhaps these changes are coming in the next AIRAC update?
Besides the VRP issue, are you saying there's an airspace change that has not been reflected in our charts?
Freccia
F
Tim Dawson - 3/21/2024 10:11:28 AM
Hi Tim, I regularly see changes POE1 and PON1 VRP in eAIP Italia
LI-ENR 6.3.1.pdf (835 views, 264.00 KB)
Freccia
F
Interesting - I will make some enquiries to determine why that document has not been updated in the Eurocontrol system. Thanks for alerting us to this.
Eurocontrol have managed to find the correct document, and we have now processed the VRP changes. You should see the chart update in SkyDemon very soon. Thanks again.
Freccia
F
Tim Dawson - 3/22/2024 10:27:15 AM
Thanks to you Tim, now I see everything as it should be.
