By Freccia - 3/21/2024 8:36:52 AM
Hi, with the new AIRAC in force from today, among other things, the Verona CTR has been modified. On SD the change is already visible however the old VRP "Desenzano" (POE1) is still present which no longer exists, because it was replaced by "Moniga del Garda" (same acronym POE1). I add that the VRP Brescia will be moved further west, changing its name to "Brescia Costalunga" (PON1). A new zone of the Milan CTA called 29 "GUSSAGO" will also be established from 2500 feet to FL195.
By Freccia - 3/22/2024 6:32:32 PM
+xEurocontrol have managed to find the correct document, and we have now processed the VRP changes. You should see the chart update in SkyDemon very soon. Thanks again. Thanks to you Tim, now I see everything as it should be.
