publicom
Visits: 116
What ist the difference between the Clouds in Virtual Radar with „Flyable“ switched on or off? The Manual says „If you have the Flyable Conditions overlay switched on, the Map Ruler will also display a layer of forecast cloud ceiling...“. Both Picture show the forecast according to the setting „Today or tomorrow“. Left with „Flyable“ switched off; right with Flyable switched on. Why does Flyable „add“ clouds?
Posts: 8.3K,
Visits: 10K
Flyable conditions include data on the cloud ceiling and lowest cloud tops. Therefore when you have it switched on, we draw that data in virtual radar to give you an idea of these two useful pieces of information.
Cloud ceiling is obviously useful for planning to avoid terrain and obstacles, and the lowest cloud tops are useful if planning to fly on top of an overcast.
publicom
Visits: 116
+xFlyable conditions include data on the cloud ceiling and lowest cloud tops. Therefore when you have it switched on, we draw that data in virtual radar to give you an idea of these two useful pieces of information.
Cloud ceiling is obviously useful for planning to avoid terrain and obstacles, and the lowest cloud tops are useful if planning to fly on top of an overcast. Thank You, Flyable is a very usefull function. But I do not understand, why there are also clouds shown in VR if Flyable is switched off. And why they differ.
Adam Erchegyi
Visits: 3.6K
+x+xFlyable conditions include data on the cloud ceiling and lowest cloud tops. Therefore when you have it switched on, we draw that data in virtual radar to give you an idea of these two useful pieces of information.
Cloud ceiling is obviously useful for planning to avoid terrain and obstacles, and the lowest cloud tops are useful if planning to fly on top of an overcast. Thank You, Flyable is a very usefull function. But I do not understand, why there are also clouds shown in VR if Flyable is switched off. And why they differ. As far as I remember, clouds on the virtual radar may also appear based on METAR/TAF
publicom
Visits: 116
+x+x+xFlyable conditions include data on the cloud ceiling and lowest cloud tops. Therefore when you have it switched on, we draw that data in virtual radar to give you an idea of these two useful pieces of information.
Cloud ceiling is obviously useful for planning to avoid terrain and obstacles, and the lowest cloud tops are useful if planning to fly on top of an overcast. Thank You, Flyable is a very usefull function. But I do not understand, why there are also clouds shown in VR if Flyable is switched off. And why they differ. As far as I remember, clouds on the virtual radar may also appear based on METAR/TAF Yes, but this still does not explain, why they are different to the clouds with Flyable.
Posts: 8.3K,
Visits: 10K
METAR are recent observed conditions in the area of the airfield.
Flyable Conditions is a forecast.
They are two different things.
publicom
Visits: 116
+xMETAR are recent observed conditions in the area of the airfield.
They are two different things. So, the left picture shows the METAR of the current situation, right? But this is only the case, if „Today or Tomorrow“ is selected. If I select a certain date (even if the date is Tomorrow), the clouds in VR disappear.
And the left picture shows a forecast for „Today or Tomorrow“, which, I think is not possible for such a big timespan. So I get a Forecast for Today od Tomorrow, and again do not get the same Forecast for a dedicated date Tomorrow.
Posts: 8.3K,
Visits: 10K
Open the What's Here menu for any point on the virtual radar and you will get an explanation of what is being drawn there.
publicom
Visits: 116
+xOpen the What's Here menu for any point on the virtual radar and you will get an explanation of what is being drawn there. That helps, thank You!
Although the What's Here Menu shows different values in the map than in VR. I added an example with the recent TAF of „St. Anton am Arlberg“. As You can see, the main cloud base differs significantly and the upper ceiling is not shown in the map at all.
Posts: 8.3K,
Visits: 10K
The values shown are the same, but only if your finger is at exactly the right point. In mountainous terrain, an AGL value will vary significantly over a small area because the cloudbase is essentially flat.
The lowest cloud top is not shown in What's Here on the main map because it is not depicted on the main map.
