Adding a point of interest to a planed route
Altomar718
A
Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)Too Much Forum (124 reputation)
Posts: 11, Visits: 7
Hi All
I was wondering how you add a 'via' point once a route is planned to somewhere which is not shown in detail on the map. Hypothetically, I plan a route from A to B but want to fly over a point of interest such as a landmark or my passengers house ?
I know you can plan a route from an airfield to a post code if starting from scratch, but cant see how this is done if that point is en route?
Chris
Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)
Posts: 585, Visits: 28K
Altomar718 - 7/18/2023 7:40:15 AM
Hi All
Chris
I’d rubber band the route leg to include the point of interest, using the aerial photography view to help if necessary.
Altomar718
A
grahamb - 7/18/2023 8:11:24 AM
Hi All
Chris
Thanks Graham but I was after how to enter a post code of somewhere as a waypoint - e.g. I am planning on flying a route and want to look at a ground feature - I can look at the website for there and get a post code, but cant enter it ? As an example, say Stonehenge .... as far as I know, it is not on SD but I can look at their website and get a post code ???
Posts: 8.1K, Visits: 9.3K
Press Find
Enter the postcode and select it when it shows in the results
SkyDemon will ask if you want to view aerial photography at the selected position, say Yes
Press and hold on the exact building/feature you're interested in, and either:
1. Select the coordinate and then the option to insert it into your route
2. Use the Create option to create a persistent user waypoint there, which you can use whenever you like to dogleg your route
Altomar718
A
Tim Dawson - 7/18/2023 9:52:07 AM
Press Find
Perfect answer ... Thank you Tim
