Adding a point of interest to a planed route
http://forums.skydemon.aero/Topic36129.aspx
By Altomar718 - 7/18/2023 7:40:15 AM
Hi All
I was wondering how you add a 'via' point once a route is planned to somewhere which is not shown in detail on the map. Hypothetically, I plan a route from A to B but want to fly over a point of interest such as a landmark or my passengers house ?
I know you can plan a route from an airfield to a post code if starting from scratch, but cant see how this is done if that point is en route?
Chris
By Altomar718 - 7/18/2023 10:01:52 AM
Tim Dawson - 7/18/2023 9:52:07 AM
Press Find
Enter the postcode and select it when it shows in the results
SkyDemon will ask if you want to view aerial photography at the selected position, say Yes
Press and hold on the exact building/feature you're interested in, and either:
1. Select the coordinate and then the option to insert it into your route
2. Use the Create option to create a persistent user waypoint there, which you can use whenever you like to dogleg your route
Perfect answer ... Thank you Tim
