No traffic visual anymore
peter@aeropoint.nl
p
Too Much Forum (121 reputation)Too Much Forum (121 reputation)Too Much Forum (121 reputation)Too Much Forum (121 reputation)Too Much Forum (121 reputation)Too Much Forum (121 reputation)Too Much Forum (121 reputation)Too Much Forum (121 reputation)Too Much Forum (121 reputation)
Posts: 11, Visits: 56
I don't see traffic anymore. I use SkyEcho2, It worked, but not anymore. I use SkyDemon on an iPad and I use the latest version.
Posts: 605, Visits: 29K
peter@aeropoint.nl - 6/11/2023 8:45:37 PM
There are many reasons why this might be the case. Diagnosing technical problems by remote control with such limited information is almost impossible.
Why don’t you give us a clue by describing what steps you have taken to try and isolate the problem?
peter@aeropoint.nl
p
grahamb - 6/12/2023 7:15:47 AM
I understand. I think the SkyEcho is not the problem, because I also tried it with SaveSky and I have the same problem there. I choose in Third-Party Devices: SkyEcho (for SkyEcho) or GLD90 (for SkySave 2.0). In Go Flying the same, but I don't see the traffic in SkyDemon. I don't know where to look further for settings that may influence seeing traffic.
peter@aeropoint.nl - 6/12/2023 3:31:16 PM
It may sound obvious, but have you made sure that you are connected to the SkyEcho wifi?
peter@aeropoint.nl
p
Yes, No doubt 😊
peter@aeropoint.nl - 6/12/2023 4:59:32 PM
Yes, No doubt 😊
I’d check the vertical filter setting in the ‘other traffic’ section of Navigation Options.
peter@aeropoint.nl
p
grahamb - 6/12/2023 7:09:49 PM
Yes, No doubt 😊
20000 ft
peter@aeropoint.nl
p
Yes, No doubt 😊
Posts: 8.2K, Visits: 9.6K
What happens when you press Go Flying, and select your SkyEcho? What do you see?
