SkyDemon Navigation
No traffic visual anymore
peter@aeropoint.nl
peter@aeropoint.nl
posted 6/11/2023 8:45:37 PM
Visits: 56
I don't see traffic anymore. I use SkyEcho2, It worked, but not anymore. I use SkyDemon on an iPad and I use the latest version.
posted 6/14/2023 10:14:18 AM
Posts: 8.2K,
Visits: 9.7K
What happens when you press Go Flying, and select your SkyEcho? What do you see?
peter@aeropoint.nl
There are many reasons why this might be the case. Diagnosing...
6/12/2023 7:15:47 AM
I understand. I think the SkyEcho is not the problem, because I also...
peter@aeropoint.nl
6/12/2023 3:31:16 PM
It may sound obvious, but have you made sure that you are connected to...
6/12/2023 4:09:00 PM
Yes, No doubt 😊
peter@aeropoint.nl
6/12/2023 4:59:32 PM
I’d check the vertical filter setting in the ‘other traffic’ section...
6/12/2023 7:09:49 PM
20000 ft
peter@aeropoint.nl
6/12/2023 7:32:02 PM
+ x [quote] [b] grahamb - 6/12/2023 7:09:49 PM [/b]...
peter@aeropoint.nl
6/13/2023 7:00:14 PM
What happens when you press Go Flying, and select your SkyEcho? What...
