Final glide
F
Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)Too Much Forum (58 reputation)
Posts: 5, Visits: 0
Well hats off to the skydemon team!!!
I made a demo panel with three units running off one BT unit
A trig radio, AV-30 and fuel flow computer
They all worked perfectly with the radio and autopilot function ticked together
The only issue was the trig had old software so didn’t work until this was updated.
What a brilliant job by Tim and the team SD just keeps getting better and better !!!
Many thanks James
Michael Hoffmann
Michael Hoffmann
Too Much Forum (544 reputation)Too Much Forum (544 reputation)Too Much Forum (544 reputation)Too Much Forum (544 reputation)Too Much Forum (544 reputation)Too Much Forum (544 reputation)Too Much Forum (544 reputation)Too Much Forum (544 reputation)Too Much Forum (544 reputation)
Posts: 51, Visits: 23
Final glide - 12/21/2024 9:11:11 AM
Well hats off to the skydemon team!!!I made a demo panel with three units running off one BT unit A trig radio, AV-30 and fuel flow computer They all worked perfectly with the radio and autopilot function ticked together The only issue was the trig had old software so didn’t work until this was updated.What a brilliant job by Tim and the team SD just keeps getting better and better !!!Many thanks James
Hi James,
what functions are controlled in the AV-30 and fuel flow computer by SD?
Michael
Final glide
F
Posts: 5, Visits: 0
Hi the SD outputs speed and track so all the nav info on AV-30 is available and on the FF computer it gets time and speed and distance so is perfect
I have a Bendix autopilot being fitted this winter and it will work that as well I am sure
What a brilliant system !
I did have a garmin handheld on the panel to feed the Av and FF but that is now on the shelf
Michael Hoffmann
Michael Hoffmann
Final glide - 12/21/2024 9:29:34 AM
Hi the SD outputs speed and track so all the nav info on AV-30 is available and on the FF computer it gets time and speed and distance so is perfect I have a Bendix autopilot being fitted this winter and it will work that as well I am sure What a brilliant system !I did have a garmin handheld on the panel to feed the Av and FF but that is now on the shelf
That sounds interesting.
Do you have any information on wiring and configuring the AV-30 to input groundspeed, track and distance?
Do you need an AV-Link or AV-HSI for these functions?
What FF computer is it?
Pictures would be fine.
Questions about questions...   Smile
Michael Hoffmann
Michael Hoffmann
Dortro - 12/21/2024 7:53:40 AM
Hi Michael,Thank you very much for both answers, this is very helpful!I was thinking to wire my BT580 to the KRT2 plug, following the diagram for connecting the remote. Your second suggestion sounds very good and, indeed, clean. Would it be expensive?My problem now is that my BT580 ls not detected by SD! I am mailing with Support about it.One of those things, it should detect the device almost immediately, but it does not…Again, thank you!
Dorto, I think 70...90 bugs, like the AR620X BLE. The problem is that I don't have a KRT2 on my desk to test.
I can't say anything about why the BT580 won't connect to SD. I haven't had a BT580 yet either.
Final glide
F
Posts: 5, Visits: 0
So for the AV-30 no avlink needed just the data wire
I have four data wires running off one BT unit !!
Elric
E
Junior Member (10 reputation)Junior Member (10 reputation)Junior Member (10 reputation)Junior Member (10 reputation)Junior Member (10 reputation)Junior Member (10 reputation)Junior Member (10 reputation)Junior Member (10 reputation)Junior Member (10 reputation)
Posts: 1, Visits: 0
I have a TY96 and a IRXO 578 V3. Is the RS-232 Connection straigth thru (RX to RX and TX to TX or is it crossed: RX - TX and TX-RX) ?
Thanks a lot in advance !
Final glide
F
Posts: 5, Visits: 0
Hi I did TX to RX from the BT to the AV-30 ETC
With a common ground line from BT to the main power supply ground for the instruments
Michael Hoffmann
Michael Hoffmann
Hello dear community,
the prototype of a TQ KRT2 BLE PnP (PlugAndPray Smile) adapter is ready.
The advantage of this dongle is that it is powered by the device itself.
You don't need any additional wiring. The size is (40 x 45 x 17) mm. Unfortunately I can't make it any smaller.
Simply plug this dongle between your existing cables - and you're done.
Yes, the correct mounting brackets are included with the final version...
I don't have them in stock yet. The screws aren't the right ones either...but that will be solved too.
It is important that the electronics work in this small space. She does.
Unfortunately I don't have a KRT2 to test and am therefore looking for a willing tester.
Is there anyone with a TQ KRT2 who can test this dongle? I'm looking for a tester in Germany, preferably in the Berlin area.
If you can and want to help here, send me a PM.
Dortro
D
Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)
Posts: 5, Visits: 0
Super!
I am interested and have a KRT2, but…I am in the Netherlands.
