Visits: 140
Hi Tim, what you write is almost correct, in the sense that these points are actually found in AIP ENR 6.3.1, however the mandatory holding gates are not very many if you consider the entire Italian territory and their use is made explicit in the related AD2 documents at each airport (section 22 - Flight Procedures).
