Mandatory holding gates
http://forums.skydemon.aero/Topic35971.aspx
By Freccia - 5/19/2023 10:44:01 AM
Hi, on SD the mandatory visual reporting points are shown with a blue background.
However (in Italy for example, see the following images) the mandatory holding gates, beyond which it is not possible to enter without having obtained authorization from ATC, are shown as normal VRPs (with a white background).
It would be very convenient for planning to see these mandatory holding gates in the same blue color as the mandatory visual report points on SD.
By Tim Dawson - 5/23/2023 9:44:22 AM
Yes - unfortunately going through all those documents each time the ENR 6.3.1 document changes does not currently fit into our workflow for Italy, sorry. Perhaps AIS will make that information part of the main definition in the future.
