Upload a route into G1000
David Johnstone
David Johnstone
Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)Too Much Forum (820 reputation)
Posts: 16, Visits: 602
I’ve searched through the archives, but have failed to find any information that will work transferring routes from
SD into a G1000
If there is a process that works I would be most grateful.
SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)SkyDemon Team (676K reputation)
Posts: 8.1K, Visits: 9.2K
There is no direct process as Garmin will not support connectivity from SkyDemon.
Some people use Garmin Pilot as an intermediate app, and some people transfer routes by way of a physical SD card.
Adam Erchegyi
Adam Erchegyi
Posts: 99, Visits: 2.3K
Maybe saving the route to an SD card and inserting it to the G1000 could work?
Oliver Voigt
Oliver Voigt
Posts: 28, Visits: 150
Here a description in german, to import a Skydemon *.fpl into G1000:
Martin Bech
Martin Bech
Posts: 152, Visits: 352
When exporting a flp, would it be possible to include flightlevel for each leg?
G1000 nxi can create vfr  visual approach, but that demands flightlevel for each leg, so the AP can handle vertical changes.
Are you saying that at the moment we export in AMSL but it would be preferable in FL, where applicable?
Martin Bech
Martin Bech
Tim Dawson - 3/6/2024 10:15:20 AM
SD is not exporting any level information in the .fpl.
I am not an expert in that file format. If you have an example where altitude or FL is specified, and could share it with me, I'll see if we can add that information to our export. That's assuming the file format actually supports it.
