Upload a route into G1000
http://forums.skydemon.aero/Topic35727.aspx
By Martin Bech - 3/5/2024 7:14:52 PM
When exporting a flp, would it be possible to include flightlevel for each leg?
G1000 nxi can create vfr  visual approach, but that demands flightlevel for each leg, so the AP can handle vertical changes.
By Tim Dawson - 3/6/2024 10:15:20 AM
Are you saying that at the moment we export in AMSL but it would be preferable in FL, where applicable?
By Martin Bech - 3/10/2024 1:19:16 AM
SD is not exporting any level information in the .fpl.
By Tim Dawson - 3/11/2024 10:32:34 AM
I am not an expert in that file format. If you have an example where altitude or FL is specified, and could share it with me, I'll see if we can add that information to our export. That's assuming the file format actually supports it.
By g-egbs - 12/12/2022 4:50:13 PM
I’ve searched through the archives, but have failed to find any information that will work transferring routes from
SD into a G1000
If there is a process that works I would be most grateful.
