Need help! error message "JIT-Debuggen"
Markus117
M
Too Much Forum (328 reputation)Too Much Forum (328 reputation)Too Much Forum (328 reputation)Too Much Forum (328 reputation)Too Much Forum (328 reputation)Too Much Forum (328 reputation)Too Much Forum (328 reputation)Too Much Forum (328 reputation)Too Much Forum (328 reputation)
Posts: 23, Visits: 24
after I planned a route I want to view the briefing pack,
but the briefing pack does not open, instead I keep getting an error message "JIT-Debuggen".
Can someone help me and tell me what I have to do now so that I can view the briefing pack again.
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.Drawing.Printing.InvalidPrinterException: Kein Drucker installiert.
 bei System.Drawing.Printing.PrinterSettings.GetHdevmodeInternal(String printer)
 bei System.Drawing.Printing.PrinterSettings.GetHdevmode(PageSettings pageSettings)
 bei System.Drawing.Printing.PrintController.OnStartPrint(PrintDocument document, PrintEventArgs e)
 bei System.Windows.Forms.PrintControllerWithStatusDialog.OnStartPrint(PrintDocument document, PrintEventArgs e)
 bei System.Drawing.Printing.PrintController.Print(PrintDocument document)
 bei System.Drawing.Printing.Printdocument.Print()
 bei System.Windows.Forms.PrintPreviewControl.ComputePreview()
 bei System.Windows.Forms.PrintPreviewControl.CalculatePageInfo()
 bei System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
 bei System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
 bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
 bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
 bei System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
 bei System.Windows.Forms.Control.InvokeMarshaledCallbacks()
************** Geladene Assemblys **************
mscorlib
  Assembly-Version: 4.0.0.0.
  Win32-Version: 4.8.9032.0 built by: NET481REL1.
  CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll.
SkyDemon
  Assembly-Version: 3.16.3.29438.
  Win32-Version: .
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe.
Divelements.Aviation
  Assembly-Version: 3.16.3.29437.
  Win32-Version: 3.16.3.0.
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Aviation.DLL.
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
System.Drawing
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
Divelements.SandGrid
  Assembly-Version: 2.2.4.1.
  Win32-Version: 2.2.4.1.
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.SandGrid.DLL.
SandDock
  Assembly-Version: 3.0.6.1.
  Win32-Version: 3.0.6.1.
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandDock.DLL.
TallComponents.PDF.Rasterizer
  Assembly-Version: 3.0.179.0.
  Win32-Version: 3.0.179.0.
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/TallComponents.PDF.Rasterizer.DLL.
System.Configuration
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
System.Core
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
System.Xml
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
Divelements.Mapping
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Mapping.DLL.
System.Speech
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll.
mscorlib.resources
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
Microsoft.mshtml
  Assembly-Version: 7.0.3300.0.
  Win32-Version: 7.0.3300.0.
  CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll.
System.Windows.Forms.resources
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
System.Web
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll.
System.Net.Http
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll.
System.Drawing.resources
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.resources/v4.0_4.0.0.0_de_b03f5f7f11d50a3a/System.Drawing.resources.dll.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration>
</configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
greetings Markus
I wonder if perhaps you have no printer installed on the machine?
