Need help! error message "JIT-Debuggen"
http://forums.skydemon.aero/Topic35343.aspx
By Markus117 - 7/27/2022 8:36:44 PM
after I planned a route I want to view the briefing pack,
but the briefing pack does not open, instead I keep getting an error message "JIT-Debuggen".
Can someone help me and tell me what I have to do now so that I can view the briefing pack again.
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.Drawing.Printing.InvalidPrinterException: Kein Drucker installiert.
 bei System.Drawing.Printing.PrinterSettings.GetHdevmodeInternal(String printer)
 bei System.Drawing.Printing.PrinterSettings.GetHdevmode(PageSettings pageSettings)
 bei System.Drawing.Printing.PrintController.OnStartPrint(PrintDocument document, PrintEventArgs e)
 bei System.Windows.Forms.PrintControllerWithStatusDialog.OnStartPrint(PrintDocument document, PrintEventArgs e)
 bei System.Drawing.Printing.PrintController.Print(PrintDocument document)
 bei System.Drawing.Printing.Printdocument.Print()
 bei System.Windows.Forms.PrintPreviewControl.ComputePreview()
 bei System.Windows.Forms.PrintPreviewControl.CalculatePageInfo()
 bei System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
 bei System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
 bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
 bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
 bei System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
 bei System.Windows.Forms.Control.InvokeMarshaledCallbacks()
************** Geladene Assemblys **************
mscorlib
  Assembly-Version: 4.0.0.0.
  Win32-Version: 4.8.9032.0 built by: NET481REL1.
  CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll.
SkyDemon
  Assembly-Version: 3.16.3.29438.
  Win32-Version: .
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe.
Divelements.Aviation
  Assembly-Version: 3.16.3.29437.
  Win32-Version: 3.16.3.0.
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Aviation.DLL.
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
System.Drawing
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
Divelements.SandGrid
  Assembly-Version: 2.2.4.1.
  Win32-Version: 2.2.4.1.
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.SandGrid.DLL.
SandDock
  Assembly-Version: 3.0.6.1.
  Win32-Version: 3.0.6.1.
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandDock.DLL.
TallComponents.PDF.Rasterizer
  Assembly-Version: 3.0.179.0.
  Win32-Version: 3.0.179.0.
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/TallComponents.PDF.Rasterizer.DLL.
System.Configuration
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
System.Core
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
System.Xml
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
Divelements.Mapping
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Mapping.DLL.
System.Speech
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll.
mscorlib.resources
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
Microsoft.mshtml
  Assembly-Version: 7.0.3300.0.
  Win32-Version: 7.0.3300.0.
  CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll.
System.Windows.Forms.resources
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
System.Web
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll.
System.Net.Http
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll.
System.Drawing.resources
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.resources/v4.0_4.0.0.0_de_b03f5f7f11d50a3a/System.Drawing.resources.dll.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration>
</configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
greetings Markus
By Tim Dawson - 7/29/2022 9:37:00 AM
I wonder if perhaps you have no printer installed on the machine?
