Declutter short airfields.
paolo.orange
paolo.orange
Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)Too Much Forum (501 reputation)
Posts: 13, Visits: 32
I set up in  aircraft setting the minimum airfield length, but shorter airfields are still visible on the map while flying.
What am I doing wrong?
Posts: 8.2K, Visits: 9.6K
You're not doing anything wrong. That field filters the airfields displayed when you open Direct To in flight. It's not designed to remove airfields from the map.
Removing airfields from the map just because they have shorter runways is not a wise thing to do.
paolo.orange
paolo.orange
Tim Dawson - 7/12/2022 11:49:04 AM
I land at 80 knots...
Fabrizio Albonico
F
Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)Too Much Forum (498 reputation)
Posts: 39, Visits: 51
paolo.orange - 7/12/2022 2:53:18 PM
You may not be able to land there, but knowing that there is an airfield nearby with possibly associated traffic is something I consider valuable information.
LSZA based
Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)Too Much Forum (9.2K reputation)
Posts: 606, Visits: 29K
Fabrizio Albonico - 7/14/2022 10:03:03 AM
Also, in the event of an engine failure, in many circumstances it will be better to land on a prepared strip that is nominally too short than take your chances with a much worse surface.
