Question regarding GPS sentence formats
tmn_pilot
t
Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)
Posts: 5, Visits: 8
Hi Skydemon.
I have a question regarding the format of GPS NMEA sentences used in Skydemon.
If I connect my 10 years old GPS receiver to Skydemon thru Wifi "Use PilotAware", it connects instantly.
However if I try to use my new GPS receiver, it will not connect.
I suspect that the issue is related to the "new" NMEA identifiers, like $GPRMC in the new receiver is named $GNRMC etc. Think it is because the receiver support GNSS.
Here is a log of NMEA from the new receiver:
2022-04-28 20:54:47.562 32328-32363/com.example.nmealog D/NMEA: $GNRMC,185448.00,A,5623.354200,N,00953.665973,E,0.0,,280422,0.2,W,A,V*60
2022-04-28 20:54:47.563 32328-32363/com.example.nmealog D/NMEA: $GNGNS,185448.00,5623.354200,N,00953.665973,E,AAANNN,21,0.6,12.9,43.6,,,V*12
2022-04-28 20:54:47.564 32328-32363/com.example.nmealog D/NMEA: $GNGGA,185448.00,5623.354200,N,00953.665973,E,1,12,0.6,12.9,M,43.6,M,,*4D
2022-04-28 20:54:48.523 32328-32363/com.example.nmealog D/NMEA: $GPGSV,3,1,11,01,85,223,21,03,48,239,14,08,14,177,33,14,11,267,22,1*62
2022-04-28 20:54:48.527 32328-32363/com.example.nmealog D/NMEA: $GPGSV,3,2,11,17,33,307,22,19,14,319,25,21,59,130,27,22,47,081,32,1*65
2022-04-28 20:54:48.542 32328-32363/com.example.nmealog D/NMEA: $GPGSV,3,3,11,31,04,105,19,32,35,056,25,04,03,188,,1*5B
2022-04-28 20:54:48.544 32328-32363/com.example.nmealog D/NMEA: $GLGSV,2,1,07,86,16,139,22,79,14,327,15,65,30,208,13,88,47,310,16,1*79
2022-04-28 20:54:48.550 32328-32363/com.example.nmealog D/NMEA: $GLGSV,2,2,07,87,80,158,13,71,40,045,33,72,77,153,16,1*40
2022-04-28 20:54:48.554 32328-32363/com.example.nmealog D/NMEA: $GAGSV,2,1,08,03,50,156,29,05,45,067,29,08,10,194,29,09,05,035,17,7*7B
2022-04-28 20:54:48.559 32328-32363/com.example.nmealog D/NMEA: $GAGSV,2,2,08,13,34,295,24,15,83,206,24,21,12,292,25,01,12,340,,7*70
2022-04-28 20:54:48.565 32328-32363/com.example.nmealog D/NMEA: $GNGSA,A,3,01,08,14,17,19,21,22,31,32,,,,0.8,0.6,0.6,1*3B
2022-04-28 20:54:48.568 32328-32363/com.example.nmealog D/NMEA: $GNGSA,A,3,71,79,86,87,88,,,,,,,,0.8,0.6,0.6,2*33
2022-04-28 20:54:48.569 32328-32363/com.example.nmealog D/NMEA: $GNGSA,A,3,03,05,08,09,13,15,21,,,,,,0.8,0.6,0.6,3*39
2022-04-28 20:54:48.570 32328-32363/com.example.nmealog D/NMEA: $GNVTG,,T,,M,0.0,N,0.0,K,A*3D
2022-04-28 20:54:48.571 32328-32363/com.example.nmealog D/NMEA: $GNDTM,P90,,0000.000024,S,00000.000000,E,0.969,W84*5E
2022-04-28 20:54:48.572 32328-32363/com.example.nmealog D/NMEA: $GNRMC,185449.00,A,5623.354200,N,00953.665970,E,0.0,,280422,0.2,W,A,V*62
All sentences have correct checksum.
Is there a solution to this, or do I have to keep using "old" GPS receivers?
Best regards
Thomas
