Question regarding GPS sentence formats
http://forums.skydemon.aero/Topic34925.aspx
By tmn_pilot - 4/28/2022 7:21:13 PM
Hi Skydemon.
I have a question regarding the format of GPS NMEA sentences used in Skydemon.
If I connect my 10 years old GPS receiver to Skydemon thru Wifi "Use PilotAware", it connects instantly.
However if I try to use my new GPS receiver, it will not connect.
I suspect that the issue is related to the "new" NMEA identifiers, like $GPRMC in the new receiver is named $GNRMC etc. Think it is because the receiver support GNSS.
Here is a log of NMEA from the new receiver:
2022-04-28 20:54:47.562 32328-32363/com.example.nmealog D/NMEA: $GNRMC,185448.00,A,5623.354200,N,00953.665973,E,0.0,,280422,0.2,W,A,V*60
2022-04-28 20:54:47.563 32328-32363/com.example.nmealog D/NMEA: $GNGNS,185448.00,5623.354200,N,00953.665973,E,AAANNN,21,0.6,12.9,43.6,,,V*12
2022-04-28 20:54:47.564 32328-32363/com.example.nmealog D/NMEA: $GNGGA,185448.00,5623.354200,N,00953.665973,E,1,12,0.6,12.9,M,43.6,M,,*4D
2022-04-28 20:54:48.523 32328-32363/com.example.nmealog D/NMEA: $GPGSV,3,1,11,01,85,223,21,03,48,239,14,08,14,177,33,14,11,267,22,1*62
2022-04-28 20:54:48.527 32328-32363/com.example.nmealog D/NMEA: $GPGSV,3,2,11,17,33,307,22,19,14,319,25,21,59,130,27,22,47,081,32,1*65
2022-04-28 20:54:48.542 32328-32363/com.example.nmealog D/NMEA: $GPGSV,3,3,11,31,04,105,19,32,35,056,25,04,03,188,,1*5B
2022-04-28 20:54:48.544 32328-32363/com.example.nmealog D/NMEA: $GLGSV,2,1,07,86,16,139,22,79,14,327,15,65,30,208,13,88,47,310,16,1*79
2022-04-28 20:54:48.550 32328-32363/com.example.nmealog D/NMEA: $GLGSV,2,2,07,87,80,158,13,71,40,045,33,72,77,153,16,1*40
2022-04-28 20:54:48.554 32328-32363/com.example.nmealog D/NMEA: $GAGSV,2,1,08,03,50,156,29,05,45,067,29,08,10,194,29,09,05,035,17,7*7B
2022-04-28 20:54:48.559 32328-32363/com.example.nmealog D/NMEA: $GAGSV,2,2,08,13,34,295,24,15,83,206,24,21,12,292,25,01,12,340,,7*70
2022-04-28 20:54:48.565 32328-32363/com.example.nmealog D/NMEA: $GNGSA,A,3,01,08,14,17,19,21,22,31,32,,,,0.8,0.6,0.6,1*3B
2022-04-28 20:54:48.568 32328-32363/com.example.nmealog D/NMEA: $GNGSA,A,3,71,79,86,87,88,,,,,,,,0.8,0.6,0.6,2*33
2022-04-28 20:54:48.569 32328-32363/com.example.nmealog D/NMEA: $GNGSA,A,3,03,05,08,09,13,15,21,,,,,,0.8,0.6,0.6,3*39
2022-04-28 20:54:48.570 32328-32363/com.example.nmealog D/NMEA: $GNVTG,,T,,M,0.0,N,0.0,K,A*3D
2022-04-28 20:54:48.571 32328-32363/com.example.nmealog D/NMEA: $GNDTM,P90,,0000.000024,S,00000.000000,E,0.969,W84*5E
2022-04-28 20:54:48.572 32328-32363/com.example.nmealog D/NMEA: $GNRMC,185449.00,A,5623.354200,N,00953.665970,E,0.0,,280422,0.2,W,A,V*62
All sentences have correct checksum.
Is there a solution to this, or do I have to keep using "old" GPS receivers?
Best regards
Thomas
By Tim Dawson - 5/6/2022 9:43:51 AM
I can't foresee a situation where we'd get much demand for it, but if we do, then we would do the work.
