W&B Planning for De-ice fluid
marioair
m
Posts: 158, Visits: 1
How do you use SD to account for De-ice fluid? If you enter it as fuel it affects the Fuel Calculations and assumes equal burn through the flight as the actual fuel. If you do it as a static loading point then you can't model max and min affects on envelope
SkyDemon Team (689K reputation)SkyDemon Team (689K reputation)SkyDemon Team (689K reputation)SkyDemon Team (689K reputation)SkyDemon Team (689K reputation)SkyDemon Team (689K reputation)SkyDemon Team (689K reputation)SkyDemon Team (689K reputation)SkyDemon Team (689K reputation)
You would just have to enter it as a loading point like any other, and enter a weight for it.
marioair
m
Tim Dawson - 1/14/2022 10:09:43 AM
Thanks. Is a feature request possible? to show the impact of the min/max values on the loading sheet?
i.e
new type of loading point = De-ice fluid with max value setting
impact on loading charts - just shows min and max impact on envelope for starting and end points only
I think this will end up being a complexity too far for SkyDemon, but I can move this thread to the Suggestions forum if you'd like input from others?
marioair
m
Tim Dawson - 1/17/2022 9:07:31 AM
Sure, happy to see what other's think.
