W&B Planning for De-ice fluid
marioair
m
Posts: 158, Visits: 1
How do you use SD to account for De-ice fluid? If you enter it as fuel it affects the Fuel Calculations and assumes equal burn through the flight as the actual fuel. If you do it as a static loading point then you can't model max and min affects on envelope
marioair
m
Tim Dawson - 1/14/2022 10:09:43 AM
You would just have to enter it as a loading point like any other, and enter a weight for it.
Thanks. Is a feature request possible? to show the impact of the min/max values on the loading sheet?
i.e
new type of loading point = De-ice fluid with max value setting
impact on loading charts - just shows min and max impact on envelope for starting and end points only
