Planning along GAFOR routes
GeKaiser
GeKaiser
Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)Too Much Forum (7.2K reputation)
Posts: 45, Visits: 312
By chance I came across a feature, but I'm wondering, how it really works: Planning along GAFOR routes in Austria
Planning a flight from LOWL to EDMV with "LO17" in the "route" field, leads to a nice flight plan along GAFOR route LO17, with several waypoints:
LSZH to LSZG via S12 works fine as well
BUT
Trying the same from LSZR to LSZH via "S13" brings up a straight magenta line and the following message, although the given airports are the official start/endpoints of S13
What's the logic behind this feature and how can I use it properly?
Tags
That feature is designed for airways routings, not for following GAFOR routes. The latter are not necessarily straight lines, they follow rivers and mountain passes, so would contain far too many turning points to usefully represent them on a PLOG.
Adam Erchegyi
Adam Erchegyi
Posts: 117, Visits: 2.4K
Tim Dawson - 8/2/2021 11:15:51 AM
You don't need to show all of the points in the PLOG. Just show the first and last points wherever the route is attached to the GAFOR route. Of course, distances/times must be calculated according to the curves of the GAFOR.
SkyDemon does not support "attaching" a route to a GAFOR route. What the OP has discovered may work some of the time but is not a supported feature.
