SkyEcho not showing other traffic
Airborn
A
Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)Junior Member (19 reputation)
Posts: 2, Visits: 11
I finally had a chance to get back in the air this week.
I connected up my Sky Echo to my ipad mini, via wi-fi, running Skydemon and set it up for the 172 I was flying. I have also purchased the Flarm addition to Skydemon.
We flew from a 77nm leg and saw several aircrft on that route, obviously I have no idea if any of them were showing ADS-B out.
At no time did I see any aeroplane icons on my ipad screen. I did get one warning of a target at my 11 o'clock, 100 feet below, I was not quick enough to note the range before the message disappeared.
When I returned i checked the configuration box on the Skydemon menu. Under statistics it says 10 ADS-B Aircraft Received, 0 Flarm Aircraft decoded.
Should I have seen aircraft icons on my screen? If so what was I doing wrong, please.
Posts: 368, Visits: 2.6K
Airborn,
Is your SE2 located in the best possible position for detecting other aircraft?
Also, are you flying in UK or elsewhere?
SD won't produce warnings or display aircraft if they aren't a threat to you.
Tony
Airborn
A
Tony N - 6/20/2021 8:15:45 AM
Airborn,
Tony
Thanks for that Tony
I fly a 172 in the southern England. I mount the unit in the front window beside the panel, so it has a clear view of the sky. Other mounting suggestions welcome.
I had assumed, wronngly it appears, that if it "saw" other aircraft it would display them on screen.
Posts: 615, Visits: 30K
Airborn - 6/21/2021 8:07:56 AM
Airborn,
Tony
I'd check the altitude filter in the SkyDemon Traffic settings.
Open it up to something like +-30000' and see if you see airliners on the SD chart; if so then reduce it to something sensible like +-2000'.
Airborn,
I also fly in southern England and think my SE2 is positioned in a very good location.
It is located above me and has a good unrestricted view forward and, probably, 70-80 deg either side of "straight ahead".
Typically, on a good flying day, I may only detect a few ADS-B Out aircraft and one or two FLARM targets if gliders are about.
You won't "see" all the commercial ADS-B traffic high above you.
If you also use your SE2 to transmit ADS-B Out you can check it out using the PAW vector application.
This gives a good indication (over a few flights)  as to whether your SE2 is positioned in a good location and not masked by crew, engine or other metal bits of your 172.
Tony
