France CAS at around RINTI - is it Class E or not?
arj
a
Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)Too Much Forum (160 reputation)
Posts: 19, Visits: 79
Hi!
Just wanted to confirm - UK IGN chart shows French Class E south of RINTI at FL65-FL115 and Class D at FL115+, and SD does not show this.
What is correct?
Thanks!
Regards,
Alex.
SkyDemon features the class D airspace but it's country-wide, so we don't show it on the main map. You can see it in Virtual Radar if you plan at that level. I can't see any evidence that class E airspace exists at that point.
arj
a
Tim Dawson - 4/6/2021 11:31:35 AM
Sent you a message with the chart that lists Class E, please take a look.
Thanks!
Regards,
Alex.
I don't do private messages on here, sorry. Unless it's an official French chart it isn't likely we'd be able to do anything with it.
arj
a
Tim Dawson - 4/6/2021 1:23:24 PM
It's Official UK CAA chart - it shows Class E in France. And French chart don't show Class E as I think they are considering it IFR airspace?
Sorry I thought you said it was an IGN chart. You're referring to the NATS-produced 1:500,000 UK South chart?
arj
a
Tim Dawson - 4/6/2021 2:12:49 PM
Sorry, correct - standard half-mil, paper one.
Thanks. I can't comment on why that chart might show class E there but I'll ask NATS. If I recall correctly, they do state somewhere on the chart that its depiction of French airspace shouldn't be considered accurate, so that is a possibility.
arj
a
Tim Dawson - 4/6/2021 2:57:27 PM
There is some AIP which (allegedly) specifies that airspace, plus the rule that all airways  below FL115 are Class E.
I'll come back later on that.
I couldn't find anything in the AIP explicitly defining any class E at that point. However if all airways are considered class E implicitly, then we wouldn't show that in SkyDemon.
