SkyEcho 2 warning pop up
colmanl
c
Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)Forum Member (48 reputation)
Posts: 5, Visits: 0
When I connect the Skyecho I get a warning saying that the configuration of the skyecho doesn't match skydemon.
I believe this comes from the requirement in the skyecho that the registration is GXXXX whereas the reg in Skydemon is G-XXXX.
Can we have Skydemon ignore the hyphen when deciding if the config is correct so I don't have this message at startup?
Otherwise a brilliant integration of 2 fantastic products!
Hmm. We ignore hyphens when making the comparison, so I don't think it can be that. Are you sure the hex codes are identical?
colmanl
c
Posts: 5, Visits: 0
Tim Dawson - 2/17/2021 11:57:22 AM
Thanks Tim all working now - It is a bit of user error there, I had clearly not saved the hex code for the aircraft in aircraft profile on Skydemon and then just assumed that it was in there instead of scrolling back down.
Maybe a suggestion would be to move the field for the hex code so that it is directly below the registration field? Not a huge issue but it may stop idiots like me making silly mistakes!
Great product!
