ios 14 issues
tony saunders
t
Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)
Posts: 6, Visits: 0
just updated my i pad mini 4 to ios 14
i know it was a silly thing to do but
now sd won't connect to sky echo 2  via wi fi
also wont connect to fsx either
i have loged it with sd support
just wondering if  pilot aware has same issues
any comments anyone?
pilot-byom
p
Posts: 323, Visits: 388
Disable the private MAC ID, that one causes quite some issues?
tony saunders
t
Posts: 6, Visits: 0
pilot-byom - 9/19/2020 8:42:05 PM
just tried that
don't make any difference i'm afraid
thank's for the suggestion
George Reid
George Reid
Posts: 113, Visits: 1.6K
tony saunders - 9/20/2020 8:13:53 AM
just tried that
I have experienced similar problems when using Pilotaware. My pilotaware is using the latest release (20200906), When I select Go Flying and instruct SkyDemon to use Pilotaware for GPS, SD on my Iphone, running IOS14 cannot connect to to the pilotaware. However if I use my Ipad, running IOS 13.7 SD can connect to Pilotaware without any problems.
I have disabled automatic updates on my Ipad until it hear that the IOS 14 issue is resolved.
George E A Reid
leemoore1966
leemoore1966
Posts: 24, Visits: 46
Pilotaware users are reporting that connections using UDP are failing, but as a fallback connecting using the flarm/TCP connection is working fine between PilotAware/SkyDemon/iOS14
Thx
Lee
Gaznel
G
Too Much Forum (447 reputation)Too Much Forum (447 reputation)Too Much Forum (447 reputation)Too Much Forum (447 reputation)Too Much Forum (447 reputation)Too Much Forum (447 reputation)Too Much Forum (447 reputation)Too Much Forum (447 reputation)Too Much Forum (447 reputation)
Posts: 26, Visits: 3
Since my iPhone 11 updated to IOS 14.0 last week and I try connect SD to PAW I only get the "CONNECTIING TO DEVICE" message, although working fine on my iPad. However, I just noticed this morning my iPhone SD has updated to version 3.14.3.258 so hopefully that will cure this. I am aiming to fly this afternoon and will report back.
Gary
iPad mini 5         IOS13.7
IPhone 11           IOS14.0
PAW classic      Version 20200909
SD on iPad         Version 3.14.2.254
SD on iPhone      Version 3.14.3.258
George Reid
George Reid
Gaznel - 9/21/2020 7:56:23 AM
Gary
iPad mini 5         IOS13.7
IPhone 11           IOS14.0
I have a similar setup.  Tried again this morning and found that SD 3.14.3.258 on my IOS14 Iphone had no problems connecting to Pilotaware.  Well done Sky Demon for fixing the issue so quickly.
George E A Reid
Edited 9/21/2020 8:39:53 AM by George Reid
iOS 14 disables access to devices on the local network unless the app "opts in". This is a breaking change, obviously.
SkyDemon 3.14.3 was released yesterday, which "opts in" so the problem should be resolved upon upgrade.
tony saunders
t
Posts: 6, Visits: 0
Tim Dawson - 9/21/2020 9:27:18 AM
hello tim
working just fine now
thanks for the prompt fix.  👌
Tom1969
T
Too Much Forum (305 reputation)Too Much Forum (305 reputation)Too Much Forum (305 reputation)Too Much Forum (305 reputation)Too Much Forum (305 reputation)Too Much Forum (305 reputation)Too Much Forum (305 reputation)Too Much Forum (305 reputation)Too Much Forum (305 reputation)
Posts: 23, Visits: 9
Hello, I also have the Problem to connect to stratux. The stratux overview Page is loading and running, but I don‘t get the connection in SD. Inhaber installed the last update of SD and IOS14 with an iPad mini 4
