Missing FMC in Schiphol TMA
Scoobydoo
S
Too Much Forum (578 reputation)Too Much Forum (578 reputation)Too Much Forum (578 reputation)Too Much Forum (578 reputation)Too Much Forum (578 reputation)Too Much Forum (578 reputation)Too Much Forum (578 reputation)Too Much Forum (578 reputation)Too Much Forum (578 reputation)
Posts: 29, Visits: 0
I‘m working on a route from Germany to Lelystad ( EHLE ). When I opened the approach VFR Chart of EHLE I received the information :
Below 1500 ft TMA 1 Schiphol monitor 124.300 and FMC 7020 . This area is all around Amsterdam but not shown anywhere in Skydemon. A friend of mine is using foreflight, and they inform you immediately about it.
How is it possible to be shown in SD as well?
Greetings Dirk
Posts: 663, Visits: 32K
It is shown in the PLOG as ‘Listening Squawk’.
Once in Navigation mode it will be also shown highlighted in pink under the Radio tab, in the Next Frequencies and Frequencies Now sections
Edited 7/28/2020 6:17:53 AM by grahamb
Scoobydoo
S
Thanks for your quick answer.
@ Tim is it possible to set it up already in planning mode, so i can see it like a TMZ style?
Thanks Dirk
It isn't a TMZ, so we wouldn't ordinarily show it as one. I don't think it's appropriate to show such an area permanently on the map.
Scoobydoo
S
Tim Dawson - 7/28/2020 9:51:15 AM
I understand that it is not a TMZ and should therefore not be shown as one. However I think it is important for the preparation of the flight. Working with the maps and airspaces would not give me any information about it.
Ibex
I
Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)Too Much Forum (71 reputation)
Posts: 7, Visits: 77
Scoobydoo - 7/28/2020 1:32:55 PM
Same issue, different area. The FMC Milano North shows up only in the list of frequencies, but how am I supposed to know its lateral and vertical limits? I'm not a friend of overloaded maps either, but maybe FMC areas can be made optional?
Edited 8/9/2020 11:00:14 AM by Ibex
Scoobydoo
S
Yes I certainly would appreciate it as well. As an option it is a great idea.
@ Tim is that possible?
We'll consider showing them on the maps. It isn't clear how they would be depicted, though, since they are not really airspace.
Scoobydoo
S
Tim Dawson - 8/11/2020 9:16:36 AM
Hey Tim, thanks for thinking about it.
If you think they are particularly well represented on some other (paper) charts you've seen, feel free to post an example or two here, that would help.
