Option to download complete product DFS AIP VFR lost since last update
Option to download complete product DFS AIP VFR lost since last update...
fzahn
f
Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)Too Much Forum (234 reputation)
Posts: 10, Visits: 21
i was always downloading all DFS AIP CFR charts to my Skydemon, to have them available offline and updting that form time to  time.
That does not work anymore, probably since last update.
In the airfields tab I click on "Download"-"Download Product" and here no product appears, but I have subscribed to the DFS VFR charts.
I see "Please wait..." for some short moments, and then just nothing.
Is this a bug?
Regards,
Florian
Posts: 663, Visits: 32K
Have you tried logging out and back in again?
Edited 7/13/2020 3:39:22 PM by grahamb
There's no known problem with downloading all plates in such a product. Do check that you're online though, otherwise the list will not populate with your purchased products.
fzahn
f
thanks for the fast reply. I was forgetting to mention, that I have this issue in the windows-version, not on iPad.
I tried to logout and login which works without problem. Also downloading a single plate from the airport-information-page works without any issues.
only downloading the complete product does not work, it is not offered in the menu:
Release 3.14.1.0
Regards,
Florian
w5400
w5400
Posts: 18, Visits: 102
fzahn - 7/15/2020 7:12:34 AM
Release 3.14.1.0
Regards,
Florian
Hi Florian
this is probably the result of a recent windows 10 update, I had the same issue. The pop-up window for dfs chart downloads is now in the upper lefthand corner of your desktop, hardly noticeable or even not visible if covered by another window.
Cheers Victor
Or maybe the submenu has appeared on another monitor? (if you have more than one)
Oddly, this only seems to happen for the 3rd Party purchases pop-up; the AIP downloads behave as before.
fzahn
f
HI Graham,
you are right, here its also in the upper left corner
@Tim: no second monitor here...
Its a little hard to click on the menu now, because if you move the mouse to it disappears. It works, if you dont run skydemon fullscreen. Then you can click on the menu in the upper left corner.
So I have a workaround.
@Tim: It looks like that:
Regards,
Florian
Thanks. We think we have a fix for the next version.
