Offline mode
Posts: 615, Visits: 30K
I see from looking at 'Forthcoming version' that the option to select 'Offline mode' is to be removed.
Could I ask that the decision to do so is reconsidered?
I currently used two iPads for navigation - one large format Pro running the current public release as my primary source, and a second Pro with the latest beta which I carry as a backup in case of issues with the primary one. Both are logged in so can be fully up to date with charts, AIPS, NOTAM etc. The former sits on my lap, the second readily to hand in the cockpit.
I also have an iPhone mounted on a sucker mount in my eyeline for traffic awareness, running an offline copy of SD, and used only to display the full-screen traffic page. This is always at the latest version, but is otherwise rarely updated, contains no charts other than the UK and is not used for planning or navigation.
As a beta tester I also use my personal iPhone for testing which I keep offline, but will juggle with logons when I wish to test on a smaller device than the iPad.
With the current restriction on two portable devices being logged on at the same time, if I understand the intention correctly, deprecating the offline option will remove my ability to carry a logged-on device as a navigation backup and a separate traffic device concurrently. It will also make beta testing on more than one device type less convenient as it will require more frequent logging on and off. Logging on when airborne just isn't possible if I needed to revert to my backup iPad.
Given that logging on and off between Windows devices is much less critical in the real world than tablet devices - as I'd imagine very few people navigate with a full Windows version - if the change were to go ahead as planned, please could you as mitigation either allow 3+1 rather than 2+2 active devices, or grant an additional allowance for beta devices.
Many thanks
Edited 6/19/2020 9:41:10 AM by grahamb
Alf
Alf
Too Much Forum (208 reputation)Too Much Forum (208 reputation)Too Much Forum (208 reputation)Too Much Forum (208 reputation)Too Much Forum (208 reputation)Too Much Forum (208 reputation)Too Much Forum (208 reputation)Too Much Forum (208 reputation)Too Much Forum (208 reputation)
Posts: 22, Visits: 20
I agree, very similar situation here!
Peter Robertson
Peter Robertson
Posts: 48, Visits: 140
Likewise with me.
Removing the ‘Offline’ Mode will certainly add a disadvantage for Beta Testers which I hadn’t considered when I replied to the Facebook post. I regularly run two screens in the plane when testing SD developments using SD Public Release and Betas at the same time for comparison. I also do the same when testing existing and Beta releases with new developments of PilotAware to ensure they don’t introduce new issues to SD. Without the ‘Offline’ mode, I would need to logout my phone each time to allow this which would leave me with no viable navigation tool should SD lose the WiFi link.
Peter
Please try the first beta (probably today) with this change before you make up your mind.
There is really no disadvantage at all to the offline mode option being removed. The device that has been logged out will tell you so, then happily continue to function with the background of the Setup button being red to remind you that it's been logged out. That's all.
Tim Dawson - 6/22/2020 9:05:54 AM
Tim,
I've installed the beta on two of my devices and had a play along with the third at the current production release. So far so good - at one point three devices were logged in; when I went back, one of them had logged itself out, but was capable of being used as you say.
Many thanks
Edited 6/23/2020 10:30:27 AM by grahamb
Glad to hear it!
Peter Robertson
Peter Robertson
Hi Tim / All
I did two test flights on Thursday evening with 2 x ‘older’ mini iPads (Mini 2 and Mini 3) - both running SD Beta 3.14.0.247 on iOS 12.4.6 ‘in parallel’ for both flights (they won’t update to anything newer), plus my old Galaxy S5 phone running SD 3.13.7.18568 ‘logged out’ as an ‘emergency backup’ on Android 6.0.1.
All 3 devices performed as advised with no issues observed, so I am happy with that.
Postscript: This does of course mean that any route or other data (including airfield plates, notams, wether, etc) which might be needed on the ‘‘emergency backup device’ MUST be loaded onto that device before your second ‘active’ device pushes the third one ‘offline’. From personal experience that should always be done on any ‘backup’ device before flight anyway and is only a minor inconvenience.
Peter
Edited 6/27/2020 10:31:08 AM by Peter Robertson
