Hide unwanted plates
alexis.hellen@gmail.com
Posts: 56, Visits: 753
Hello, what do you think of having the option to hide plates we don't want or need?
This could be done manually, the same way we can hide Notams. SD would then have to take this into account and only automatically show the plates that have not been hidden. Also, if SD cash figure this out, it could automatically hide HEL approach and departure charts depending on the aircraft we have selected. Furthermore, once we have drawn a track, SD could adapt what we see to automatically show us approach plates when the landing leg is activated or departure when the departing leg is activated. And also, could it be possible, that when approaching an airport for which both an area and a visual approach charts are available, that a window pops up with only these two options that we could simply chose from?
Thanks again for a great app!
Cheers, Alexis
Are there really so many plates you do not wish to see? Could you give some examples at a couple of popular GA airfields?
Hello Tim,
Here are examples.
Cheers,
Alexis
Tim Dawson - 5/26/2020 10:49:13 AM
Hello Tim,
What do you think of this idea after having seen the examples I shared?
Cheers,
Alexis
My personal feeling is that there are not enough airfields with loads of plates to warrant what would necessarily be quite a complicated user interface to selectively hide them, offer options for unhiding them, etc. As with all posts in this forum I was waiting for others to weigh in on the discussion, as we cannot implement such things unless we're fairly sure the problem exists for a good proportion of users.
Tim Dawson - 7/9/2020 9:26:56 AM
Fair enough, thanks for your input. Cheers, Alexis.
Lars
L
Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)
Posts: 1, Visits: 0
I have been using Skydemon for IFR flights for a few weeks now.
It would be helpful if I could select just one STAR, approach and one SID (chart + SID text) and have a button on the right side of the screen (like for notams, weather, radio and airports) were I can slide the chart into view.
Consider an IFR training flight A-B-C. At airport B we start with a STAR or RNAV transition, fly the approach and use a SID for departure.
Most approach charts are geo-referenced. Most SIDs and STARs aren't.
So, I can see the approach easily, but if I need to review the transition or SID, I have to open the PDF file from the airports tab.
It is feasible to switch apps in Android, but Skydemon on my device opens the PDF file in the external viewer BUT I can not switch back to Skydemon without closing the PDF again.
During climbout I have to be heads down to open the airports tab, (sometimes with the wrong airport open by default) select "Instrument Plates", dig through the list (check EDWE - the Y and Z approaches are mixed up) and select the proper SID. Probably not the smartest thing to do at low altitude.
If I could populate buttons for STAR, Approach and SID I could just quickly switch back and forth as required - especially if the charts would open directly in Skydemon without third party apps.
