LSGG ATIS frequency doesn't come up in radio tab
alexis.hellen@gmail.com
Posts: 56, Visits: 753
Yesterday night while flying into LSGG, the radio tab didn't show the ATIS frequency (see prt scr) while this information is in the Approach Information field. Is there a setting I need to change somewhere?
Cheers,
Alexis
Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)Too Much Forum (9.7K reputation)
Posts: 616, Visits: 30K
alexis.hellen@gmail.com - 5/21/2020 7:52:48 AM
Cheers,
Alexis
If you look elsewhere (e.g. the PLOG or the 'What's Here' popup) the ATIS frequencies are shown as 135.580 and 124.755, so the problem is not they are missing, but that in the Radio tab they are labelled as 'Information' and not ATIS.
grahamb - 5/21/2020 9:54:26 AM
Cheers,
Alexis
Well spotted grahamb, that is absolutely correct. Thanks.
alexis.hellen@gmail.com - 5/21/2020 6:09:10 PM
Cheers,
Alexis
What puzzled me is the fact that in the LSGG FIR, the service is called Geneva Information, which is the same name used for the ATIS in the SD Radio Tab.
I agree it would be more helpful if we simply showed ATIS here, so we will make that change for the next version.
Tim Dawson - 5/26/2020 9:24:26 AM
ThanksTim for changing this.
On the other hand, now there are two frequencies that are called ATIS: from what I gathered getting the web, the "standard" one is 135.580 whereas the other one send to be a glider dedicated ATIS.
I will ask my colleague if there is anything we can do about this.
We've added a note to the frequency for gliders, hopefully this will make things clearer with the next chart update.
