When adding aircraft in library and syncing with cloud they disappear
max
m
Posts: 2, Visits: 1
on Windows when I add .aircraft files in documents ==> skydemon ==> aircraft I can see them in the aircraft library in Skydemon on my PC.
Now I want to sync them so they also appear on the mobile devices. When I push "sync with cloud" they disappear and are also deleted in the aircraft folder on windows.
How do I sync them and get them into the cloud?
Max
If you're adding them directly into the filesystem you may be adding older versions than have been recently deleted in the cloud. To make sure they're treated as brand new files, copy them into the filesystem before opening SkyDemon then modifying something about them within SkyDemon, to bring them up to date, before syncing.
max
m
Posts: 2, Visits: 1
Thank you, that solved my problem!
