TMZ Wittmund missing again in 2020
cbk
c
Too Much Forum (144 reputation)Too Much Forum (144 reputation)Too Much Forum (144 reputation)Too Much Forum (144 reputation)Too Much Forum (144 reputation)Too Much Forum (144 reputation)Too Much Forum (144 reputation)Too Much Forum (144 reputation)Too Much Forum (144 reputation)
Posts: 14, Visits: 66
die german dfs has announced the TMZ Wittmund again in 2020. Unfortunately it is the same procedure as last year, so they announced it without a Trigger-NOTAM and today even without publishind it in the AIP SUP.
Listening Frequency: 131.015 MHz
Sqwak: 4472
efrenken
efrenken
Posts: 265, Visits: 3.5K
Just copied from SD Notam section:
Temp transponder mandatory zone tmz Wittmund established: 532110N0071141E 533547N0070700E 533938N0071338E 534249N0080202E 533146N0080908E 532232N0080706E 531844N0072026E 532110N0071141E. Vertical limits 2500FT MSL - 5000FT MSL, 1000FT AGL - 5000FT MSL within area 532431N0072545E 533610N0071636E 533847N0072539E 533953N0075431E 532853N0075909E 532512N0075228E 532431N0072545E. Times of activity 19 December 2019 0700 - 25 March 2020 2359, HX. The times of activity depend on those of the Wittmund control zone. The following information on the times of activity gives a rough indication concerning the expected activation: Mon-Thu 0700-2200, Fri 0700-1200. Activation outside the times published and/or deactivation within these times is possible at all times and will be announced by NOTAM. Information about the current status of the tmz Wittmund may be requested on frequencies 118.730 MHZ (Wittmund tower), 131.015 MHZ (Wittmund radar) or 125.100 MHZ (Langen information).
In the tmz Wittmund, aircraft flying under VFR, except for model aircraft and unmanned aircraft systems, shall be equipped with an automatic altitude reporting transponder and shall set their transponder to code 7000 without request to do so. Exceptions from this obligation may be granted by the competent ATC unit via Wittmund radar via written agreement or radiotelephony if the safety of air traffic is not impaired.
In addition, the following urgent recommendation applies: in addition to setting transponder code 4472, it is highly recommended to maintain continuous air-ground voice communication watch on frequency 131.015 MHZ (Wittmund radar) when flying in the tmz.
1000FT AGL - 5000FT AMSL.
cbk
c
I also found it after intensive search. As I planed a flight through the TMZ for January 14th, 10:00 UTC 3000ft msl, I was not able to find the TMZ in the map.
efrenken
efrenken
cbk - 1/12/2020 4:51:03 PM
This is, I guess, because it is a temp(orary) TMZ.
The old one expired and they only just released a SUP establishing the new one. You should see it on your map as of earlier this morning, but in the meantime, looks like they issued a NOTAM.
Tom1969
T
Too Much Forum (267 reputation)Too Much Forum (267 reputation)Too Much Forum (267 reputation)Too Much Forum (267 reputation)Too Much Forum (267 reputation)Too Much Forum (267 reputation)Too Much Forum (267 reputation)Too Much Forum (267 reputation)Too Much Forum (267 reputation)
Posts: 23, Visits: 9
Hello
TMZ Wittmund not lover active. The TMZ end on 25.03.2020
https://aip.dfs.de/supplements/vfr/SUP_03_20.pdf
Thanx
pilot-byom
p
Posts: 323, Visits: 388
Tom1969 - 4/6/2020 9:36:22 PM
Hello TMZ Wittmund not lover active. The TMZ end on 25.03.2020https://aip.dfs.de/supplements/vfr/SUP_03_20.pdfThanx
Hasn't the TMZ being established now in the AIP? Last year they told me the SUP would only be until next revision and it would be permanent, so no longer NOTAM or SUP needed.
Yes, that's right.
