Unable to create aircraft profile from existing profile
plume_tray
plume_tray
Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)Too Much Forum (8.2K reputation)
Posts: 116, Visits: 434
Just downloaded the latest SD v3.13.1 on iOS, and I can't see a way to create a new aircraft profile from my own existing aircraft profiles.
I fly a lot of different types and registrations on a regular basis. It required a bit of work to set up the profiles (fuel, CG etc), as none the aircraft I fly exist in the "Add Aircraft" list.
As I already have each type/variant that I need, I just duplicate a profile for each registration. I used to be able to rename one of my own existing aircraft profiles, then load from cloud the old version, therefore maintaining a copy of the old and new profiles on my device.
I can't do this with the new version. Ideally, it would be handy to have a "Duplicate" or "Copy Aircraft" button / slide gesture. Otherwise, be able to see my existing aircraft profiles in the "Add Aircraft" list, perhaps in a separate list to the standard list.
That's a good point. In the meantime if you're on a PC you can simply copy the files in the filesystem. On a tablet it's trickier, you could temporarily change the name/reg of an aircraft then load a route which had the old one, and at that point in the aircraft manager SkyDemon will ask you if you'd like to add the route-attached one to your library. We will get a Duplicate option added though.
