TMZ transponder code / monitoring frequency
Trial
T
Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)Forum Newbie (8 reputation)
Posts: 1, Visits: 2
Hi, is it possible to display the TMZ transponder code as well as the monitoring frequency?
For Example TMZ EDNY, Code 2677 / Monitor 119.925,
Next issue, TMZ EDNY is shown on my map, but for example TMZ of EDJA not ?
thanks & regards
Christian
Posts: 606, Visits: 29K
Trial - 11/28/2019 7:10:51 AM
thanks & regards
Christian
Which version and OS are you using?
On iOS with the latest version and charts, EDJA TMZ is shown on the chart.
Monitoring codes and frequencies are show on the What’s Here  pop-up when you touch inside the TMZ, and also on the Radio tab and Pilot Log as ‘Next Frequencies’ as you approach the airspace when navigating.
Edited 11/28/2019 7:41:13 AM by grahamb
efrenken
efrenken
Posts: 265, Visits: 3.5K
I can confirm what grahamb is saying.
Eric
Posts: 8.2K, Visits: 9.6K
All TMZs in Germany (and indeed in Europe) are shown on the SkyDemon map in the same way as other airspace (e.g. airspace higher up may be hidden due to decluttering). The frequencies and transponder squawks can be read by tapping on the map as others have said.
