Scratchpad clear functionality
Gerhard66
G
Posts: 175, Visits: 358
would it be possible to remove the „clear“ functionality from the scratchpad!?
I lost my notes in bumpy air by accidentally touching this field.
A „clear“ function is not necessary. One can easily open a new page.
In the old analog world, I also can’t remember a pilot using a rubber to erase his paper- scratchpad instead of using a new sheet ;-)
Gerhard
I suspect that removing this functionality would result in a lot of frustrated customers, as does removing virtually any functionality that has existed for a long time.
efrenken
efrenken
Posts: 265, Visits: 3.5K
Hi Gerhard,
How could you discard the page if you don‘t need it anymore in case you cannot “clear” it?
Eric
Gerhard66
G
Hi Eric,
I just tap „next“ (Page) and I have a new, clean page without the risk of loosing information.
After restarting SD prior to the next flight, SD starts with a new Scratchpad anyway.
Gerhard
Scoobydoo
S
Too Much Forum (540 reputation)Too Much Forum (540 reputation)Too Much Forum (540 reputation)Too Much Forum (540 reputation)Too Much Forum (540 reputation)Too Much Forum (540 reputation)Too Much Forum (540 reputation)Too Much Forum (540 reputation)Too Much Forum (540 reputation)
Posts: 29, Visits: 0
I have the problem with the scratch pad, that quite often when I write on it, long lines from left to right will be signed. This is quite annoying when I have to write fast. On the Ipad Notepad app I don‘t have this problem with my apple pencil.
Any idea how I could improve?
