Weather icons on map sometimes wrong
pgroell
pgroell
Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)Too Much Forum (5.4K reputation)
Posts: 100, Visits: 17K
For a flight to an airfield where TAF shows good weather with green icon for all day, the icon on the map is red.
First time I see this and a few airfields are affected on my map.
See attached picture with discrepancy for the destination LFLC. (Flight to begin 2 hours after picture is taken)
Maybe I misunderstand something.
Edited 7/18/2019 6:39:54 AM by pgroell
Posts: 368, Visits: 2.6K
Pgroell,
Check your setting in "Weather Minima" under "Settings" / "Planning Options".
You can change the criteria regarding which symbol is displayed to represent good/marginal/poor etc.
Tony
We've reviewed this for the next version, as there are some things that aren't entirely clear about the way SkyDemon shows the weather blobs on the map. The blob in in the title in the Weather window shows the state of the TAF at the beginning (its main part) whereas on the map, as you slide the time slider forwards and backwards, the blobs change colour to represent the specific part of the TAF for the time you've selected.
If you're on the SkyDemon Beta for iOS you can check out the changes now, if you like.
pgroell
pgroell
Hi Tim, I knew of the changing icon (blob!) with time but in my example the blob should never be red for a flight in the TAF's timeframe.
I'm' not on the IOS beta team have no time for that but knowing this has been adressed is enough for me.
Will check the next update.
Pascal
