small issues/errors on belgian charts
jfw
jfw
Too Much Forum (9.4K reputation)Too Much Forum (9.4K reputation)Too Much Forum (9.4K reputation)Too Much Forum (9.4K reputation)Too Much Forum (9.4K reputation)Too Much Forum (9.4K reputation)Too Much Forum (9.4K reputation)Too Much Forum (9.4K reputation)Too Much Forum (9.4K reputation)
Posts: 134, Visits: 485
Just wanted to feedback some minor charts issues for Belgium:
EBBR - Brucargo VRP is not showing on the chart while the name is
EBCI - arrow threshold - VRP N is in wrong direction // arrow threshold - VRP S is in wrong direction // arrow threshold - VRP WN is in wrong direction
Not that important but anyway....
Brucargo appears to be obscured by the airfield boundary detail when zoom right in, but otherwise it's there for enroute purposes. Does that fit what you're seeing?
Before I report the other matters to my colleague, I don't understand what you mean by "arrow threshold", could you explain? Many thanks.
jfw
jfw
Tim Dawson - 4/13/2019 8:17:27 AM
It seems indeed that the 'BRUCARGO' VRP is "under" the airfield while the VRP name is "above". I assume this is a layer order issue.
Regarding my other comment: there is a line between VRP and runway threshold. The arrow on this line is in the wrong direction: it should be
-from runway threshold to VRP N
-from runway threshold to VRP NW
-from runway threshold to VRP S
as the lines are depicting departure paths (note:from runway threshold to VRP SE is correctly depicted)
Hope this clarifies.
Br,
J
Thanks, I will pass these comments along.
