SkyDemon and SkyEcho 2
Thommy
T
Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)
Posts: 4, Visits: 8
I got a new SkyEcho2 from uAvionix and had the opportunity to test it yesterday in real!
It worked!
I have the flarm option for SD and configured the SkyEcho also for Flarm reception and was really happy to have it!
Make a long story short:
SD told me that I have traffic at 12 o’clock when I was downwind for EDTG.
An ultralight started and flew direct after takeoff into the downwind path for EDTG.
I was very surprised and because of the silhouette and the terrain I saw it very late just before I was to abort the approach.
So happy to have both SD and SE2 :-)
Greetings Thomas
Alf
Alf
Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)
Posts: 22, Visits: 20
after hours of testing the combination of SD and SkyEcho 2, I would like to say, that I am more than happy! First, I fly a vintage plane with no electrical system (no transponder etc.). So, until now I was completely blind and no one could see me, resulting in a couple of dangerous situations in the past. Now I use an Android Phablet, SD, SkyEcho 2 and Bose A20 Bluetooth as headsets.
The firmware of my SkyEcho 2 had to be updated after delivery. Then I subscribed the Flarm license and went flying. Binding the SkyEcho2 to the Phablet was no problem, also the Bose A20 via BT with the same device. I selected bearingless targets in SD and of course the SkyEcho as external device. At the first flight I was quite disappointed, all traffic could be seen on the screen (heli, glider and other VFR traffic, even airliner), but there was no aural alert in the headsets. I turned media level to the maximum in the Android device, still no alerts. After landing the problem was clear, the A20 has separate buttons for BT sound level, and that was at a minimum...On the second and following flights everything was perfect, aural alerts from SD regarding terrain etc. and traffic alerts! I had about 5 flight hours since then, and only once one single engine aircraft, which crossed my path 1000ft above, was not shown in SD (but possibly this aircraft had turned off it´s Mode C or S).
Conclusion: For me as a vintage aircraft user, with no electrical system on board, this combination is big step forward and makes flying much safer. On the other hand, pilots with installed FLARM or Mode S/C systems, e.g. a Garmin system, might have more advantages (see problematic Mode S/C indications in SD (bearingless targets) in other threads)).
Cheers,
A.
Edited 6/4/2019 7:19:35 AM by Alf
Posts: 393, Visits: 2.6K
Hi Alf,
I also fly a vintage aircraft with no electrical system.
However I do have a Trig TT21 transponder with ADS-B out connection, Trig TY91 8.33 VHF radio and also a Horis 80 AHRS.
I power this equipment using a 12V 5.2AH Li-Ion battery which lasts at least 8 flying hours between re-charges.
So it is possible to be equipped with a transponders etc. without a full aircraft electrical system.
I am still undecided which way to go with having an electronic conspicuity receiver capability.
I like the SE2 but it can only detect ADS-B and FLARM. Also I would need to disable the SE2 Mode-S transmissions as I have a transponder.
PAW is on the list and will be interesting to see how the new MLAT capability works.
Tony
Alf
Alf
tnowak - 6/5/2019 8:04:40 AM
Hi Alf,
Tony
Hi Tony,
thanks for the information, sounds great, I will take a look at the mentioned instruments. I am afraid, that my cockpit is too limited regarding space (old bi-plane) for a transponder.
Keep care,
Alf
TouchTheSky
T
Posts: 153, Visits: 4.6K
Hi Alf,
Tony
I think it is worth mentioning here that a Stratux Europe version has now been created:
Alf
Alf
TouchTheSky - 6/5/2019 6:32:29 PM
Hi Alf,
Tony
Thanks for the hint, I have never heard something about Stratux. Sounds interesting. Is there an advantage compared to SkyEcho 2?
Thanks for clarification.
BR
TouchTheSky
T
Alf - 6/5/2019 7:53:09 PM
Hi Alf,
Tony
BR
Well, BoM (bill of material) is less than € 150, it receives ADS-B and FLARM and connects to all major EFBs including SD over GDL90 protocol. Several sources offer ready-to-fly versions for € 279 or DIY kits for € 225
Furthermore there are a couple of folks (including myself) that maintain the code and develop it further.
Alf
Alf
TouchTheSky - 6/5/2019 8:00:05 PM
Hi Alf,
Tony
BR
Thank you for the quick reply. You folks are great, really like this. My question was more towards: Does it have the same functionality as SkyEcho 2 with the FEB 2019 Firmware, ADS-B in/out, Flarm AND Mode S/C bearingless reception?
Cheers,
Alf
TouchTheSky
T
Alf - 6/5/2019 8:07:36 PM
Hi Alf,
Tony
BR
Cheers,
Alf
Stratux Europe Edition is only an "in" device, meaning ADS-B in and FLARM in. In addition Mode C/S targets are also received and displayed on the "Radar" page but not forwarded to the connected EFB.
Alf
Alf
TouchTheSky - 6/6/2019 4:52:35 AM
Hi Alf,
Tony
BR
Cheers,
Alf
Understood, thank you!
