SkyDemon Flight Planning
Pilot Log - Flightplanning
mafeistswiss
m
mafeistswiss
posted 2/27/2019 8:09:09 AM
m
Visits: 0
1st.) would be great if there is a possibility to adjust the Pilot Log with some add. fields (for example: engine hours on the tachometer- ToH) - closed to the Startup / BlockOff / ... section
2nd.) official phraseology for thís section is:
- ToH
- Startup
- Block OFF or OFF Block
- Takeoff
- Landing
- Block ON or ON Block
- Shutdown
- ToH
3rd.) I prefer the following structure, because reading from left to right, next line is not the best here
Left side of this section: Right Side of this section
- ToH - Landing
- Startup - Block ON or ON Block
- Block OFF or OFF Block - Shutdown
- Takeoff - ToH
However: I highly appreciate this SW - very innovative, stabil, highly useful and lots of functions for VFR and also IFR flights.
regards
Martin
Tags
flight planning
pilot log
Edited
2/27/2019 8:13:36 AM by
mafeistswiss
posted 2/27/2019 10:14:01 AM
Posts: 8.3K,
Visits: 10K
Thanks for your feedback. Some of the logging functionality you are requesting is already present in SkyDemon.
Your post is really a suggestion, so it might be best in our Suggestions forum where other people can comment on it. You're also welcome to contact our support directly in case you've missed any SkyDemon features and are requesting things that already exist but not where you're looking.
