Feature Request : Copy Aircraft In Library
HardyK
HardyK
Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)
Posts: 10, Visits: 22
After spending a good deal of time inputting details for a particular aircraft (especially Power Settings profiles) I would like to simply copy that aircraft since others of the same performance and hourly rate etc. are available at the club.
Unless I'm missing something (?), after a few minutes I finally realised I can do this by selecting the aircraft to be copied then:
- 'Save to Cloud' and use a new filename.
- 'Load from Cloud' and open the new file.
- Select one of two identical aircraft that now appears in the library list (i.e. the one without the green tick).
- Edit the registration and save.
It's no great effort I suppose but it feels like a faff for a simple task.
Please add a 'Copy Aircraft' button alongside 'Use Aircraft' in Aircraft Library which does just that but, before saving it, invites the user to input a new registration.
Unless I really am missing a trick?
SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)SkyDemon Team (624K reputation)
Posts: 7.8K, Visits: 8.4K
On a PC, go to your Documents folder, then SkyDemon, then Aircraft. You can copy the aircraft files as much as you like.
HardyK
HardyK
Tim Dawson - 1/2/2019 4:54:09 PM
Got it. Thank you.
