Visits: 4.9K
Are you using this tablet device with a mouse, or using the touchscreen?
If using the touchscreen, are you using a stylus or your finger?
Most touchscreens need a double tap to drag. You double tap, then keep your finger down on the second tap whilst dragging. Practice by moving your icons around on the desktop first. It can be tricky.
If you're using a proper stylus, there may be some settings in the driver which affect how 'dragging' works.
With regard to manually entering coordinates, they must be entered in an exact manner. For example:-
N 50º57'32" E0º21'18" must be entered as:-
N505732 E0002118
If you need greater precision (unlikely!), you can use decimal seconds:-
N505732.34 E0002118.56
