planning a route on my tablet pc.
http://forums.skydemon.aero/Topic2693.aspx
By woodysr2 - 4/25/2011 5:54:08 PM
I am having a couple of issues with the software at the moment.
1 I cannot drag the route line once I have set start and destination points ( although this was possible when using evaluation prog. since I have purchased the license this feature has gone?)
2 I have tried to manually input waypoints with absolutely no success using the waypoint insertion tab.This is most annoying as I have had to sit and tap the screen a fraction at a time to try and get position exact (didnt happen but as close as I was able without spitting the dummy and hurling pc at the nearest wall LOL)
I can still drag route on the desktop pc but same problem with adding waypoints.
Any help most welcome.
I will contact skydemon after the easter break to try and resolve this
Cheers
William
By pink leader - 4/28/2011 12:27:05 PM
One other way is to start by entering the main waypoins  .. say two airfields, start & end. Then tap and hold on a point to which you want to "drag" the line. You will then be given the option to "insert" that point between the first 2.
I have use this method quite easily to go around airspace etc while en route. Think it wd also be feasible in a flexwing.
D
