Unhandled Exception - No Printers are installed
deanflyer
d
Posts: 1, Visits: 0
T‌ried viewing airfield information and kept getting an unhandled exception. I've worked out it doesn't like my default Dell 3330 laser printer, as it works fine when I select Microsoft PDF as the default printer. Skydemon is 3.9.5.0. OS is Windows 10 64-bit.
D‌etails as below:-
System.Drawing.Printing.InvalidPrinterException: No printers are installed.
 at System.Drawing.Printing.PrinterSettings.GetHdevmodeInternal(String printer)
 at System.Drawing.Printing.PrinterSettings.GetHdevmode(PageSettings pageSettings)
 at System.Drawing.Printing.PrintController.OnStartPrint(PrintDocument document, PrintEventArgs e)
 at System.Windows.Forms.PrintControllerWithStatusDialog.OnStartPrint(PrintDocument document, PrintEventArgs e)
 at System.Drawing.Printing.PrintController.Print(PrintDocument document)
 at System.Drawing.Printing.Printdocument.Print()
 at System.Windows.Forms.PrintPreviewControl.ComputePreview()
 at System.Windows.Forms.PrintPreviewControl.CalculatePageInfo()
 at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
 at System.Threading.ExecutionContext.runTryCode(Object userData)
 at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
 at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
 at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
 at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
  Assembly Version: 2.0.0.0
  Win32 Version: 2.0.50727.8922 (WinRelRS4.050727-8900)
  CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
SkyDemon
  Assembly Version: 3.9.5.21034
  Win32 Version:
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe
  CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
  CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
  CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Divelements.Aviation
  Assembly Version: 3.9.5.21033
  Win32 Version: 3.9.5.0
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Aviation.DLL
Divelements.SandGrid
  Assembly Version: 2.2.4.1
  Win32 Version: 2.2.4.1
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.SandGrid.DLL
SandDock
  Assembly Version: 3.0.6.1
  Win32 Version: 3.0.6.1
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
  Assembly Version: 3.0.105.0
  Win32 Version: 3.0.105.0
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
  CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
  CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Divelements.Mapping
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Mapping.DLL
SandBar
  Assembly Version: 1.4.3.2
  Win32 Version: 1.4.3.2
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandBar.DLL
enabled.
For example:
<configuration>
</configuration>
Posts: 8.1K, Visits: 9.3K
That's a nasty one. SkyDemon isn't actually part of that error chain, so there's not a lot we can do about it. At least it tells you why it's having trouble. It's the Microsoft printing engine trying to prepare for SkyDemon to print something (or show a preview of printed stuff) but it doesn't give us a chance to handle the error, sadly.
