By deanflyer - 5/24/2018 12:49:26 PM
Tried viewing airfield information and kept getting an unhandled exception. I've worked out it doesn't like my default Dell 3330 laser printer, as it works fine when I select Microsoft PDF as the default printer. Skydemon is 3.9.5.0. OS is Windows 10 64-bit.
Details as below:- See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.Drawing.Printing.InvalidPrinterException: No printers are installed. at System.Drawing.Printing.PrinterSettings.GetHdevmodeInternal(String printer) at System.Drawing.Printing.PrinterSettings.GetHdevmode(PageSettings pageSettings) at System.Drawing.Printing.PrintController.OnStartPrint(PrintDocument document, PrintEventArgs e) at System.Windows.Forms.PrintControllerWithStatusDialog.OnStartPrint(PrintDocument document, PrintEventArgs e) at System.Drawing.Printing.PrintController.Print(PrintDocument document) at System.Drawing.Printing.Printdocument.Print() at System.Windows.Forms.PrintPreviewControl.ComputePreview() at System.Windows.Forms.PrintPreviewControl.CalculatePageInfo() at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8922 (WinRelRS4.050727-8900) CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll ---------------------------------------- SkyDemon Assembly Version: 3.9.5.21034 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8922 (WinRelRS4.050727-8900) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8922 (WinRelRS4.050727-8900) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8922 (WinRelRS4.050727-8900) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- Divelements.Aviation Assembly Version: 3.9.5.21033 Win32 Version: 3.9.5.0 CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Aviation.DLL ---------------------------------------- Divelements.SandGrid Assembly Version: 2.2.4.1 Win32 Version: 2.2.4.1 CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.SandGrid.DLL ---------------------------------------- SandDock Assembly Version: 3.0.6.1 Win32 Version: 3.0.6.1 CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandDock.DLL ---------------------------------------- TallComponents.PDF.Rasterizer Assembly Version: 3.0.105.0 Win32 Version: 3.0.105.0 CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/TallComponents.PDF.Rasterizer.DLL ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8922 (WinRelRS4.050727-8900) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.8922 (WinRelRS4.050727-8900) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Divelements.Mapping Assembly Version: 3.9.5.21033 Win32 Version: 3.9.5.0 CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Mapping.DLL ---------------------------------------- SandBar Assembly Version: 1.4.3.2 Win32 Version: 1.4.3.2 CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandBar.DLL ----------------------------------------
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
By Tim Dawson - 5/30/2018 9:14:10 AM
That's a nasty one. SkyDemon isn't actually part of that error chain, so there's not a lot we can do about it. At least it tells you why it's having trouble. It's the Microsoft printing engine trying to prepare for SkyDemon to print something (or show a preview of printed stuff) but it doesn't give us a chance to handle the error, sadly.
