Visits: 110
Oops sorry, indeed I am. However looking on the current maps, part of the TMA starting eastward from the Gran Paradiso restricted area abeam Forzo then upward to CHamprocher, Issime, Piedicavallo, Varallo, Gravellona, Premosello is clearly labeled A from FL 170 to FL195 only. There are similar areas eastwards of it - surely if they're on the maps they are (or should be) somewhere in the AIP, i'll make sure to find the appropriate chapter.
And yes, considering i just flew vfr to and from Lugano (LSZA) no longer than two weeks ago through what SD depicts as class A and the map as class G without being intercepted /shot down/causing raised eyebrows i'm pretty sure the maps are accurate.
