License for multiple devices
Ashkirby
Ashkirby
Posts: 14, Visits: 46
Renzo - 6/12/2017 8:27:28 AM
I don´t need a third one
If you are planning on using SkyDemon on three devices, like you have stated above, then yes I believe you do need a third mobile licence.
I‌f you simply want to use your phone as a backup in case of hardware failure, then putting up with an error message on the failed device should not really be an issue, as I would assume once back on the ground you would re-log back in on the failed device and the working iPad and this would then log-out the backup mobile.
J‌ust out of curiosity, what are you using two iPads for simultaneously showing SkyDemon in the cockpit?‌
Richard.Payne
R
Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)Forum Member (47 reputation)
Posts: 14, Visits: 47
I would like to request that the limit be increased to 3 generally.  This is my reasoning:
I have 2 tablets, one primary, one backup.  These live in my flight bag and get configured with my planned route.
I also have SD on my phone and use it for keeping an eye the weather, notams, etc. when I'm not near my bag.
What concerns me is that I login on my phone which then logs out my backup device.  If my primary fails in flight then I will have to try to login on the backup in the cockpit, which is not ideal and maybe not even possible.
There is a fundamental difference in scenario that Tim outlined above.  When the device disconnects from the internet it does not remove the login session tokens and SD will continue to operate.
Adam Erchegyi
Adam Erchegyi
Posts: 123, Visits: 3.4K
I second this, 2+1 mobile + desktop usage is not unusual nowadays. I am willing to pay a reasonable extra!
Richard, the situation describe above works just fine with the status quo. It doesn't matter if your backup device has been logged out because you logged in a different device. It'll still work just fine for navigation in an emergency.
We suffer a great deal already with people sharing their subscriptions with their friends. That is the reason we do not offer three simultaneous mobile devices on one personal license.
Adam Erchegyi
Adam Erchegyi
Tim Dawson - 5/7/2025 10:17:19 AM
...and how do you keep the charts updated? :/
If it is crucial to you that your backup device has the very latest charts* you can log it in once a month, update them, then log back in on your main device.
* it could be argued that a traditional backup is a paper chart, which is only updated once per year.
Richard.Payne
R
Tim Dawson - 5/8/2025 9:40:55 AM
Yeah, to be fair, it's on us to ensure that any devices we plan to use, even if only planned as an emergency back, are up to date.
My main concern was not being able to navigate without logging in.  If this is not a problem, then all good.
Feel free to try it. SkyDemon will tell you that you've been logged out, but it doesn't stop you using the data already on the device to navigate with.
Posts: 657, Visits: 32K
Richard,
FWIW I use a third device (an old iPhone 6 as it happens) as a traffic radar display every time I fly. It works fine in navigation mode without being logged in. I log it in from time to time just to update the charts just in case (I have a fourth device, also not logged in, which I do update monthly as Tim suggests to use as my backup to my backup device 😊)
Just remember not to press Yes in the heat of the moment when it prompts you with the ‘Do you want to log this device in’ question and you’re out of WiFi range …. 😢
Edited 5/9/2025 9:49:46 AM by grahamb
