After Beta 3.8. Only the problems..
Please take some responsibility for your own settings. This is not a software bug, and blaming us will not help. Somebody has changed your map settings so that airspace below or above your altitude is hidden, I guess. Just change the setting back.
This has nothing to‌‌ do with beta 3.8, and contrary to your assertions, nobody else has reported anything remotely similar happening.
When you log in, even after deleting and reinstalling the software, your settings are loaded from the cloud. That's why SkyDemon appears to remember your home airfield position, and that's why whatever map settings you have chosen will persist too.‌
cocoroman
c
Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)Too Much Forum (6.8K reputation)
Posts: 70, Visits: 116
GEAR - 4/30/2017 11:19:23 AM
cocoroman - 4/30/2017 10:25:23 AM
GEAR - 4/30/2017 7:29:18 AM
To reinstall an earlier version of SkyDemon you first must uninstall the version that is currently on your tablet.
Then using the web browser on your tablet go to the SkyDemon Android page  https://www.skydemon.aero/start/android.aspx‌.  Scroll down on that page and you will find a list of earlier versions.  You can then download the version that you want.
If you have trouble installing the software after you have downloaded it you may need to set the security settings on your tablet to allow software installation from unknown sources‌.  The following link explains how to change the settings
https://gs4.gadgethacks.com/forum/enable-unknown-sources-android-install-apps-outside-play-store-0150603/‌
Hi George, yes I did uninstalled and these for x times, I have even factory reset my Nexus. I have uninstalled also from my Samsung galaxy S6 have even uninstalled the PC version, just to try clean early version install, like 3.7 and 3.7.1. Thats why I am writing on this forum. It is not working like it did before, no Flight and mode it shows all, but when I start to Fly or Simulate, Notams are disappearing and some of Military TMA's are also gone. But when I stop Flying they are back again, there for I have tried to Unhide hidden Notams also x times but no go. I don't know why it will remember even my Home Airfield, though I have deleted everything for sure. I also have re downloaded from my early Cloud setup I have made I think all possibilities. But no, it's not working anymore. There must be something that I do wrong; but I don't know what. Cheers.
Have you tried to install version 3.7.0.   I had some problems with 3.7.1 and reverted to 3.7.0.   I have loaded 3.8 beta but have not yet tried it out in the air.
Yes, I did installed 3.7.0 same story, I have noticed one thing; When I raise the ceiling of my Flight. e.g. 1000 to 3500 then I can see the TMA's. But still Notams are disappearing etc. I try again today hope that will work. I have also have written to the Support, sure they will answer me soon. Thanks for your help. Cheers.
George Reid
George Reid
Posts: 113, Visits: 1.6K
George E A Reid
cocoroman
c
George Reid
George Reid
George E A Reid
cocoroman
c
O.K. folks, since few days, I am struggling to reinstall earlier versions like 3.7. because 3.8 Beta sucks. But I have noticed it is no more possible, at least for the moment. I have done everything, even I have Factory reset it my Nexus 10 and I have also removed whole SD from my Samsung Galaxy S6. Tonight I will also remove my PC version of SD. But I have really enough .....
I‌ was told that I should have re saved on the Cloud the working version, but it is not working at all. Same story, well O.K, did I bought a Product or a problem.
One more thing, since SD 3.8 came, I hear and see only the problems. On the same time, they push us to try, well the result, is really very bad for everyone who has been tried. Tim I must tell you, unfortunately you are a not big help man. So somebody should tell me, how I should make it work the older versions. Because nothing is working again. It even remembers my Home Airfield, though I have removed from every where..
