After Beta 3.8. Only the problems..
http://forums.skydemon.aero/Topic23030.aspx
By cocoroman - 4/29/2017 9:08:27 PM
O.K. folks, since few days, I am struggling to reinstall earlier versions like 3.7. because 3.8 Beta sucks. But I have noticed it is no more possible, at least for the moment. I have done everything, even I have Factory reset it my Nexus 10 and I have also removed whole SD from my Samsung Galaxy S6. Tonight I will also remove my PC version of SD. But I have really enough .....
I‌ was told that I should have re saved on the Cloud the working version, but it is not working at all. Same story, well O.K, did I bought a Product or a problem.
One more thing, since SD 3.8 came, I hear and see only the problems. On the same time, they push us to try, well the result, is really very bad for everyone who has been tried. Tim I must tell you, unfortunately you are a not big help man. So somebody should tell me, how I should make it work the older versions. Because nothing is working again. It even remembers my Home Airfield, though I have removed from every where..
By Tim Dawson - 5/2/2017 12:32:33 PM
Please take some responsibility for your own settings. This is not a software bug, and blaming us will not help. Somebody has changed your map settings so that airspace below or above your altitude is hidden, I guess. Just change the setting back.
This has nothing to‌‌ do with beta 3.8, and contrary to your assertions, nobody else has reported anything remotely similar happening.
When you log in, even after deleting and reinstalling the software, your settings are loaded from the cloud. That's why SkyDemon appears to remember your home airfield position, and that's why whatever map settings you have chosen will persist too.‌
