Visits: 25K
I have approx 300 routes saved. I have habitually named virtually all of them in the format ‘XXX DEP-DEST [via AAAA] [Other Qualifier] where:
XXX is VFR or IFR. DEP is Airport of departure, always a meaningful name except when it’s EGCW, my home base. DEST is Destination airport, as above AAA optionally would specify a particular route The Other Qualifier may be used to annotate any other discriminator.
Routes extend to, from and within a number of Western European countries; some go back nearly as long as SkyDemon has existed, I’ll often plan a long multi leg trip some time in advance, playng with a number of options, whilst researching accommodation options for the overnight stops. If IFR it may take several iterations for each leg back and forth with EuroFPL or Autorouter to get an efficient route validated. I’ll keep routes, as though things may change, a route that has worked before is always the best starting point for flying to the same destination again.
I haven’t fully thought through yet how I would use folders, but the ability to save a basket of routes for a specific trip would be useful; as would grouping them by country or other area.
